I am a new Flex-3000 owner. I need some guidance on setting up my 3000 for CW mode. I really need some fairly detailed instructions to set things up for CW operation. If this has been already covered would someone point me to the messages. Any help would be really appreciated. Thank you.
Robin
W4IEN
Setup for CW
Re: Setup for CW
The Setup all depends on how you operate CW.
For example: When I operate CW its usually using the CWX macros (see the CWX button at the top of PowerSDR) for Transmit, and "CW Skimmer" (search my webpage for info on that) for Receive.
Setup->DSP->Keyer is the CW panel if you intend to use a KEY or paddle.
