"Reply" and "CQCQ" Buttons Topic is solved
I just used the "Reply" and "CQCQ" buttons for the first time during yesterday's NAQP to play .wav files. It worked great and definitely saved my voice. I had one issue, though. The pop-up balloons associated with each of these buttons say that they stay in "focus" and one can then use the enter key to trigger them. I was unable to get this to work and had to click on the buttons every time I wanted to play the file. Am I missing a setting somewhere that needs to be engaged for the "enter key" aspect to work? What am I doing wrong? I tried both of the "enter" keys on my keyboard; the one on the alpha-numeric portion and the one on the numeric keypad to the right.
Flex 3000 & 5000
Hercules MP3e2
Dell OptiPlex 990 w/i5 2400 CPU @ 3.1GHZ
Windows 10
Hercules MP3e2
Windows 10
Re: "Reply" and "CQCQ" Buttons
Your correct. I will try to fix it.
Re: "Reply" and "CQCQ" Buttons Topic is solved
Go download .187
F3 key is now "Reply" voice keyer button
F4 key is now "CQCQ" voice keyer button
I updated the keyboard map pdf as to reflect this change.
I had to remove the global ENTER key (last button pushed) feature because I added the "Setup->general->hardware config->SpaceBar Hold to PTT and Spacebar Latch ON/OFF to PTT, CHECKBOX options.
ke9ns.com
ke9ns.com
Excellent! Thank you very much
Flex 3000 & 5000
Hercules MP3e2
Windows 10
Hercules MP3e2
Windows 10
