old versions of power sdr Ke9NS
hi, where can i find old versions of power sdr? I need the 245 but I don't know where to download it, thanks.
Re: old versions of power sdr Ke9NS
if you hold your mouse over the Green incremental download link, you will notice the full name of the download.
Earlier downloads are still there, copy use the same full download but change the .247 to one of the older ones.
it doesn't work, if I go with the mouse on the green tab nothing happens, I also changed the browser.
"right click" the Green incremental download link and select "copy link".
"right click" in your browser URL area and "paste" it into your browser URL
Then only change the version number to whatever version you are after. ( .247 to .245 )
press enter or click the arrow on your browser
The below link will get you version .245
https://ke9ns.com/PowerSDR_KE9NS_V2.8.0 ... taller.msi
NON VA, stesso errore con la 245
what Error?
same as before
245 at 247
245 at 247
- Resizer_16424305335790.jpg (1.7 MiB) Viewed 22975 times
