Roger Beep
zetagi
Roger Beep
Post by zetagi »
for certain situations a roger beep would be helpful for me. for Sat operation with Transverter.
e.g. 200 ms at 2475 Hz (Quindar-Tone) ;)
is there a possibility in powersdr?
Re: Roger Beep
I was experimenting with quindar tones. download the latest .190 and check out Setup->keyboard and see what you think.
zetagi
Re: Roger Beep
Post by zetagi »
thank you very much Darrin for the great implementation!!!
the start and end sequence, real quindar, that's really great. nice is the Monitor to hear the tone
Is it normal that after releasing the PTT the transmitter stops to transmit and start again immediately and then comes the end tone?
Re: Roger Beep
No, you have an early version.
install .191
When you release the PTT the radio stays transmitting until the End tone is done.
zetagi
Re: Roger Beep
Post by zetagi »
thank you for the information.
unfortunately the problem still exists .191
I have also made a completely new installation. Flex 3000
When releasing the PTT, the PowerSDR stops/start briefly and then comes the end tone
Philipp
Re: Roger Beep
When you unkey the radio, you will see the MOX button will stay RED, MON button will turn RED and the Play button turn GREEN, while it plays the end tone, then all 3 will turn off.
On the 3000 I only tested it with the standard MIC on the front of the radio and my old laptop, but it works just fine.
If you see the STOP/START button flicker there is some other issue related to your database and playing wav files.
go to "Wave" and make a voice keyer VK1 recording and then try to play it (hit the VK1 button on the console), see if anything flickers?
zetagi
Re: Roger Beep
Post by zetagi »
I think I have found the problem.
if VAC1 is deactivated it works
