TURF update Topic is solved
MM0XXW
TURF update
Post by MM0XXW »
I'm running PSDR version 2.8.0.303 and tried following the instructions to change the location from US to UK however I can't seem to find the button in question!
Is it just me or has the TURF button been moved elsewhere? :oops:
MM0XXW
Re: TURF update
Post by MM0XXW »
Thanks I'll give it a try!
IK8HCG
Re: TURF update  Topic is solved
Post by IK8HCG »
1) CTRL + SHIFT + D
2) Low level hardware tab
Select the TURF you want on the screen.
MM0XXW
Re: TURF update
Post by MM0XXW »
Doesn't work in .304 :roll:
Re: TURF update
It works.
If you can not get to the hidden screen, you must have PowerSDR in "Focus" before hitting the keyboard.
If you changed your TURF, but dont see the change, you must cycle power on your 13.8vdc supply to see the update.
Then when you re-launch PowerSDR, do a Setup->General->Options->"Update BandText"
