Can I update from v2.8.0.194 to v2.8.0.306 directly without any problems?
I am using an HP Z440, 64 bit with Xeon CPU E5-1650 v4 @3.6 GHZ
Windows 10 Pro for WS, version 22H2
Thank you
Jerry
Updating from v2.8.0.194 to v2.8.0.306 Topic is solved
Re: Updating from v2.8.0.194 to v2.8.0.306
Forgot to mention I am using a Flex 5000
versions published on the KE9NS site will not affect after version 2.7.2 it is clearly written
If you are currently running .194, you can just install the .306
However.... New features added to PowerSDR since .194, may cause your database file to become corrupted after the upgrade to .306
So, I suggest you do a setup->export database before performing any upgrade.
So if you find a problem, you can do a setup->import database
And YES.. it will not touch the FlexRadio v2.7.2 version. That version resides in a different sub-folder than my v2.8.0 version.
Re: Updating from v2.8.0.194 to v2.8.0.306 Topic is solved
Thank you Darrin and IK8HCG!
The update worked flawlessly. I did not have to import the backup database.
