It was working just fine for months. Today, I cannot get any receive audio. I've tried different bands and different modes - all silent?
I have MUTE off
I have Squelch zero -(to the left)
Antenna 1 selected
If I use RX2 - I get receive audio just fine.
It must be some setting that I screwed up
no receive audio 5000A v2.8
Re: no receive audio 5000A v2.8
Assuming your talking about the audio output on the back?
First toggle the MUT button, just in case.
Then check the "Mixer" (top line of the Console screen), that has a mute all its own.
Assuming your powered speakers are working and plugged in, plug in headphones and check that as well.
After cycling power to everything, if its still not working, do a setup->factory defaults.
Found It !!
Somehow the 'VAR1' button was selected in the filter area. Turns out that button mutes receive (in ssb). I selected the correct filter width - bingo.
All is well...
All is well...
