Flex 3000 ATU problem using KE9NS PSDR Topic is solved
wa4mit
Post by wa4mit »
Hello in versions of your PSDR software the ATU is not available by this I mean it is not active (icon is dark) and I can not activate it even in tune mode. I can activate ATU by going to the ATU dropdown but not from main screen. I also have the original PSDR on my computer and with this running I can activate the ATU and it is available icon is active and "ATU" is white I can use the ATU if tune is activated. This problem is occurring with versions .129 and .146 that I am able to try.
Thanks for any help 73 Morris WA4MIT
Re: Flex 3000 ATU problem using KE9NS PSDR  Topic is solved
Check and make sure the TUN button does not say TUNp (pulse tune).
In TUNp, I turn off the ATU because the tuner doesnt work well with pulses.
wa4mit
Post by wa4mit »
Thanks Darrin that seemed to have solved the ATU problem now the ATU is active and working.
Many thanks 73
Morris WA4MIT
