Does the memory interface and scanner work with RX2? I can't find a selection for RX2 but not sure if I am setting the interfaces up correctly.
Thank you
Jerry
Memory Interface and Scanner with RX2
Re: Memory Interface and Scanner with RX2
I have not setup the scanner for anything but RX1, But I may add a provision.
I dont believe the memory screen is setup for anything but RX1 as well?
