using a lesozoh headset with flex 1500
KD8PYY
Post by KD8PYY »
I have this setup with the correct adaptor for the flex 1500. the 2 wires y ing off 1 black 1 red ? what's the proper hook up and I'm using a foot switch , it keys the flex , but no audio?? I new, first time with a Flex 1500
Txs
KD8PYY
Jack
Re: using a lesozoh headset with flex 1500
If you were trying to send an image, send it again.
KD8PYY
Post by KD8PYY »
Sent you an email to your email address, for some reason it wouldn't attach here??
Jack
So you have some sort of adapter to plug the TRS connector of your Headset MIC into the RJ45 connector of the Flex-1500?
Or are you using the Headset plugged into your PC and want to connect your PC spkr and mic to the Flex-1500?
KD8PYY
Post by KD8PYY »
sent pic again to email. 2 of them
I am assuming your headset is for a PC (i.e. gamers headset)?
I am assuming your headset has 2 TRS cables (1 for the Headphones, 1 for the Mic)?
I would think the Headphone plugs directly into the Flex-1500, and the MIC TRS probably needs voltage (i.e. Electret mic)?
If that is the case, then the Ring maybe set to require +5v (which is pin 3 of the RJ-45 Flex-1500 connector), the Tip would go to pin 5, the Sleeve would go to pin 4. But I dont know the Headset?
