XVRX resets to XVTX/COM
w8aef@q.com
Post by w8aef@q.com »
I usually spend my time on 144 or 432 MHz using Transverters and XVTX/C and XVRX ports on my Flex-1500.
However when I drop down to 6M for a little fun, then return to 144, I find that the ANT > Antenna > Receive: has reset to XVTX/COM. Is there any way to make the XVRX setting sticky?
Unfortunately I sometimes forget to reset the Antenna Selection and wind up calling CQ on a 'dead' band because the Transmit does stick.
de Paul, W8AEF
Re: XVRX resets to XVTX/COM
What version of PowerSDR are you currently running?
w8aef@q.com
I believe I have found the solution to my problem. I had the Antenna > Lock ticked. I unticked it, which to my is counterintuitive, and all seems well now.
