Hi,
first of all thanks KE9NS for his support and for develope of this fantastic software.
I bought a second hand 1500, works great and no problems, very happy.
-The side tone on my CW sounds perfect if I use the phone output of the radio, but with the software I doný ear nothing, neither with the key nor with the memories. I move the MON pot but only works to adjust volumen of sidetone CW with the earpohnes into the phone jack of the radio.
thanks for readme and 73.
Jon EA3BV
1500 and several dudes
Re: 1500 and several dudes
If you want to hear via your PC, you need to run VAC1 (typically set to default Speaker and Mic)
Using VAC1, make sure the MON is on "MONps" not "MONpr" if you want to monitor your TX CW via the PC speakers
The S-meter should work.
When you transmit the "FWD PWR" meter does not move in CW mode on a Flex-1500
Its probably because there is no FWD/REV power meter in the Flex-1500 (like there is in the Flex-3000/5000)
If your not getting any output (using an external power meter) with the Drive level set to 100, then you could try a setup->Factory defaults and start over, otherwise there is something wrong with the radio.
Monitor CW: the problem was "MONps" not "MONpr", now I ear my CW on PC (with VAC, of course).
The rig has power output, about 4.5w, perhaps in CW the S-meter doesn´t meter for not SWR in 1500, yes. TNX
Anyway, to make CW I use external phones output from rig because via Pc the delay is horrible when I TX.
1500 and actually Power SDR works great, fine job, Darrin.
