Hi,
using v2.8.0.248, the Production TRX/IO Test gives me several errors for the receiver tests (filter, level, image). Also fro the RX2 tests/alignments.
With the last "official" version 2.7.2 the tests and alignment procedures run OK, with the exception of the 60m band, where the image fails.
Any hints on this?
73, Chris
Receiver self tests and alignment
Re: Receiver self tests and alignment
Hi Chris
I have the same result
Roland HB9NCZ
Roland HB9NCZ
You can only run calibrations when your at the absolute default settings. So the only way would be to go into the database folder and remove all 5 database files to guarantee a default database on the next power up.
But its possible that I changed some of the default settings over the years, so if that still fails, you will need to use 2.7.2
