PSDR Won't Launch.
N0DFF
PSDR Won't Launch.
Post by N0DFF »
Just finished up updating to ver 2.8.0.166, and PSDR won't finish loading. Bar graph on banner page gets nearly all the way to the right, then displays "Power SDR has stopped working", and to exit, I must close the program. Have re-loaded it twice. Running Win 7 Pro, SP1, i7 desktop, 64 bit, 32 gb ram. This setup has been bulletproof till today..
Thanks, Steve
Re: PSDR Won't Launch.
I would download .166 incremental over again.
Then install 2 times. 2nd time select Repair. See if that works.
Otherwise go into the database folder and move all the files with your radios serial# in the file name
Then after its up and running, you can try to to import your database file back into PowerSDR.
Darrin ke9ns.com
N0DFF
Post by N0DFF »
Will do, Thanks!
N0DFF
Post by N0DFF »
Ended up being a bad update download. Re-loaded everything & it works great again. Had all databases & memories backed up and that made it MUCH easier..
