I noticed last night that after being on 2 meter FM, when I went back to the SSB mic profile, the settings for FM were still in effect for the the TX EQ. Guess I did not sound good. As soon as I touched a slider in the TX EQ, all of the EQ sliders changed to their correct positions for the SSB profile. Anyone had this?
Thanks, & 73
EQ Settings not Following Mic Profile.
Re: EQ Settings not Following Mic Profile.
I am working on saving all the different EQ's to the TX profile
Should have it soon.
That's great Darrin! It's not so serious now that I know to check it each time I switch profiles. THANKS for all you do!!
Steve N0DFF
Steve N0DFF
I have also noticed the issue, and I agree with Steve, thanks for all your continued hard work Darrin
I think I have it working (saving all EQ's for each TX profile) in .165
You may lose your current 28EQ band data as you select a prior TX profile, but once you resave the TXprofile, now it will now save anything you had for the 10band GEQ, 28 band GEQ and the 9 band PEQ for each TX profile.
I have tried to make the code update your current database and not force you to create a fresh database.
9-Band Parametric EQ TXEQ not turning on until I touch a slider. I noticed this after I upgraded to the v2.8.0.172
Not a big deal since I know that I can slide a control up or down to active it before I talk, but was curious if others have had this issue.
Darrin, Thank You for this forum and the sharing of your program expertise.
N4JGO
N4JGO
I will check it out
I checked out the 9-band PEQ on my Flex-5000 and it works correctly on a TX profile changeover or a Power UP.
But its possible that there is a timing & speed issue that maybe causing it to miss loading up automatically.
I will see if I can tweak it.
