AGC-T line on 2m & 70cm
jerryco
Post by jerryco »
I have been using the AGC-T line function you created and this is very helpful and fun to use. It works well on HF but I noticed when working on 2m and 70cm I can use the hand and grab the line to move the AGC-T line toward the top of the screen but when I try to grab the line to move it toward the bottom of the screen (below the noise floor) it won't move down. It actually jumps a little higher on the screen each time I try to grab it. I can move the line up or down where ever I need with the AGC-T slider button with no problems.
Thank you for all the features and functions you have added to the KE9NS version of PSDR!!
Jerry
KX0I
Re: AGC-T line on 2m & 70cm
Post by KX0I »
Jerry,
I had the same issue here. Try going to setup->Display. Play with the slide controls, especially AGC-T line adj. I found a setting moving it near left edge that made it work better.
Bob, KX0I
I dont think I ever tried it beyond the HF.
I need to check it out.
jerryco
Post by jerryco »
Bob,
Thank you for the tip. I was able to get it set so I can grab the line. It is better and I can move the line up and down now although it is still a little bit unstable.
Jerry
