Hi All, I was trying to update on my Win 10 machine at home, The Win 11 machine Updated OK.
I am now wintering in AZ and I cannot update the Win 10 machine. I have captured the screens..see attached.
Second problem. When I try to run WSJTX on existing PSDR 2.8.0.245 it ignores the Com ports selected and set up with VSP Manager...and says I cannot use com ports 2 or 3. When I go back to PSDR 2.7.2 it all works fine with same settings???
Best 73
Barry VE4MA
Installation problem with 2.8.0.260 on Win10?
- PSDR V2.8.0260 Installation Problem 2.jpg (37.44 KiB) Viewed 22199 times
- PSDR V2.8.0260 Installation Problem 1.jpg (36.41 KiB) Viewed 22199 times
Re: Installation problem with 2.8.0.260 on Win10?
I have never encountered that fault before.
if installing .263 doesnt work you may need to uninstall everything and re-install the Full installer first (again) before the .263 incremental.
V2.7.2 only allows for 1 COM port pair, v2.8.0 allows for 6 COM port pairs. The PowerSDR setup->CAT Control screen is very different.
