How do you set up port to send CW?
AA2MA
Post by AA2MA »
I'm trying to set up N1MM+ to key the PowerSDR/FLEX 1500 and send CW. N1MM+ CONFIG dialog allows me to set up a port to use either DTR or RTS to send CW, however I don't see a similar setting in any of the PowerSDR SETUP sub-menus. Is there a way to send CW using an external program via the virtual serial connections?
Thanks and 73
de AA2MA
Re: How do you set up port to send CW?
I have never done this, but check out setup->DSP->keyer->Connections->Primary or Secondary->CAT
When you select CAT: PTT LINE, KEY LINE boxes will appear
ke9ns.com
AA2MA
Post by AA2MA »
That does the trick. Thanks. Didn't think to look under the DSP tab for a keyer menu. Expected to see that under Transmit or possibly under CAT.
73, Mark
aa2ma
