Cannot use PowerSDR v2.8 after
antennadad
Post by antennadad »
Hello Folks, I just downloaded .108 and did Firmware Update and now I cannot run the program. Tried rebooting. Same. I snipped the fatal error and it is attached. I am running Windows 10 Pro. Any ideas? Thanks, Rod
Fatal Error.JPG (104.36 KiB) Viewed 12234 times
Re: Cannot use PowerSDR v2.8 after
That is a database corruption. It can happen when you upgrade from one version to a newer version.
go to folder: %userprofile%\AppData\Roaming\FlexRadio Systems\PowerSDR v2.8.0\
and remove all the files with your radios matching serial number. (there are usually 5 files: 1 main and 4 backups)
Now when you launch PowerSDR it will create a new factory defaults database.
If you previously made a backup database (i.e. setup->export database), you can try to load it in (setup->import database).
antennadad
Thanks for the reply.
I was unable to locate that string, so I uninstalled and reinstalled .107 to start over. I think the databases files were running out of a old, improperly named folder.
73,
Rod
