PowerSDR v2.8.0.237 number display problem Topic is solved
DH2ID
Post by DH2ID »
with the latest update the old number display problem cropped up again.
I run PSDR on Win 10 pro and German region settings, where the comma
is the decimal separator and the point separates number groups.
The attached screenshot shows that numbers are repeated in the VFO window.
I went back to .235 and deleted the FlexRadio settings in AppData Roaming and
played back my backup. Everything works again. Just to let you know, all else
works well. Thank you for the great program,
Vy 73, Alex - DH2ID
Re: PowerSDR v2.8.0.237 numer display problem
Try downloading .236 and see if that is OK?
This is the download to the .236:
https://ke9ns.com/PowerSDR_KE9NS_V2.8.0 ... taller.msi
in .237 I compiled the program using Microsoft's new Visual Studio 2022
in .236 and earlier programs I compiled using Microsoft Visual Studio 2019
So its possible there is an issue with the new compiler?
Also, if you install .237 and do a factory defaults and start fresh is it OK?
DH2ID
Re: PowerSDR v2.8.0.237 number display problem
Post by DH2ID »
I've installed .236 which works fine with my Flex-1500, which I use
as a testbed. .237 still causes the number problem.
DH2ID
Re: PowerSDR v2.8.0.237 number display problem  Topic is solved
Post by DH2ID »
Thank you for .238, but I can't download it - page error 404...
UPDATE: Works now, thank you. Will try the new .238 later.
UPDATE2: Tested on the Flex-1500 with .238new: OK, all numbers displayed correctly.
UPDATE3: Tested on the Flex-300. OK.
