old versions of power sdr Ke9NS
Questions and issues related to Flex Firmware updates and Turf Region.
ale66
Post by ale66 »
hi, where can i find old versions of power sdr? I need the 245 but I don't know where to download it, thanks.
IK8HCG
Re: old versions of power sdr Ke9NS
Post by IK8HCG »
can I ask why you ask for an old version? simple curiosity
lou
The old incremental files are still up on the server.
If you see the incremental download link, just change the current .263 to whatever version.
https://ke9ns.com/PowerSDR_KE9NS_V2.8.0 ... taller.msi
FYI:
New versions of PowerSDR can sometimes cause your database to become corrupted. (As I add new features I add more to the database)
So its always a good idea to do a "Setup->Export Database" as a future backup.
But once corrupted, going backwards to an older PowerSDR, may not fix a corrupt database issue.
At that point, if you can get into PowerSDR, do a Setup->import database and put your good backup in)
otherwise go to the database folder: %userprofile%\AppData\Roaming\FlexRadio Systems\PowerSDR v2.8.0\
and remove all the files with your radios serial number in the file name (to FORCE a factory default reset)
