Wow one thing after another. So when I invoke VAC1 or 2 I get an unhandled exception error. unhandled exception has occurred in your application.
Object reference not set to an instance of an object. How can I fix so I can handshake to HRD??
unhandled exception
Re: unhandled exception
Right click on VAC1 and make sure "Select A" is checked ON, then Driver = DirectSound and select Input and Output drivers
