Audio IN/OUT using VoiceMeeter
WA3PWX
Post by WA3PWX »
Trying to get WSJT-X to work with VoiceMeeter. What do I specify for IN and OUT for both PowerSDR and WSJT-X since the inputs and outputs in VoiceMeeter don't match Darrin's example.
Re: Audio IN/OUT using VoiceMeeter
I downloaded Voicemeeter "Banana", maybe you downloaded something other than Banana?
With Banana, they give a separate names (in and out) to each end of 2 different virtual audio cables. (The main, and "AUX" audio cables)
Many virtual audio drivers only show 1 name for both ends of the audio cable.
If you go to windows control panel->SOUND, what are the available "Playback" and "Recording" devices listed?
