The current version of Windows 10 Pro currently has Assembly Version 4.0.0.0 not Version 3.0.0.0 so V2.8.0.122 fails as soon as the mouse moves. Here is what the message says:
************** Exception Text **************
System.IO.FileNotFoundException: Could not load file or assembly 'AutoItX3.Assembly, Version=3.0.0.0,
Culture=neutral, PublicKeyToken=a646454c8d475470' or one of its dependencies. The system cannot find the
file specified.
File name: 'AutoItX3.Assembly, Version=3.0.0.0, Culture=neutral, PublicKeyToken=a646454c8d475470'
at PowerSDR.Console.Console_MouseEnter(Object sender, EventArgs e)
at System.Windows.Forms.Control.OnMouseEnter(EventArgs e)
at System.Windows.Forms.Control.WndProc(Message& m)
at System.Windows.Forms.Control.ControlNativeWindow.OnMessage(Message& m)
at System.Windows.Forms.Control.ControlNativeWindow.WndProc(Message& m)
at System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
************** Loaded Assemblies **************
mscorlib
Assembly Version: 4.0.0.0
Win32 Version: 4.7.3394.0 built by: NET472REL1LAST_C
CodeBase: file:///C:/Windows/Microsoft.NET/Framework/v4.0.30319/mscorlib.dll
Thanks, Mont O'Leary, K0YCN --- k0ycn@arrl.net
Windows 10 Pro AutoItX3.Assembly Version 3 missing
Re: Windows 10 Pro AutoItX3.Assembly Version 3 missing
I forgot to add the file into the Full Installer.
I have now added it.
But you can just download the Incremental Installer (Green button) and install that, or go back on download the Full Installer overa gain (either way will work)
Darin,
I reran the full installer and V2.8.0.122 now works like a champ! Thank you very much for adding the AutoItX3 files.
Mont K0YCN
Mont K0YCN
