Figured out easy way to operate WSJT-X in a SPLIT mode (i.e. FT8 with JA on 160m)
VFOA=1908, VFOB=1840, TX=VFOB, click on VFO Lock button until it reads "VFOA/B Loc". Set WSJT-X to radio=TS-2000 Split=None
Note: Ignore the MultiRX. You do not need it on.
WSJT-X SPLIT operation on PowerSDR
- screen_cap-20191118-221202.jpg (39.51 KiB) Viewed 17939 times
Re: WJST-X SPLIT operation on PowerSDR
Thanks Darrin, that really helped. Just worked 4 JA stations on 160 in FT8. I tried before with VFO Lock but did not enable VFO A/B Lock in Setup->General Options->"VFO Lock A/B". Probably a bug in WSJT-X ...
Re: WSJT-X SPLIT operation on PowerSDR
I am confused as to what this does?
I run mine using the split setting in WSJT just fine (also set as a TS-2000).
Am I missing something?
Mike,
How do you setup your PowerSDR and WSJT-X for the JA split on 160m?
The way I described, you dont really do anything on the WSJT-X side.
I couldnt figure out how to do the proper JA split from within WSJT-X?
I figured there had to be a way to avoid using VFOB?
