When I attempt to update in the "about" tab, I receive the attached message.
Tom W7TJM
Update issue Topic is solved
Update issue
- 2020-03-31_17-52-31.png (23.6 KiB) Viewed 359862 times
Re: Update issue
it should be fixed now.
go and download and install the latest. Hopefully that does it.
Re: Update issue
I had the same problem with .158. Tried a reinstall repair and did not work. Downloaded 159 separately and did an install. Same error on getting an update. Did a repair reinstall of .159 and same thing. Each time, the pc was restarted.
This is in Win10
73 K8SAS
This is in Win10
73 K8SAS
Re: Update issue
I'm still getting the same error.
But it really isn't a big deal, because I can still go to your webpage and download manually.
But it would be more convenient to use the "about" tab to see if there was any new updates.
Tom
Tom
Re: Update issue Topic is solved
Finally figured out what was going wrong.
Its fixed with .163
Its fixed with .163
Re: Update issue
.163 fixed the update issue
Tom W7TJM
Tom W7TJM
Re: Update issue
Thanks Darrin, 163 fixed my problem also!
73 - Steve
73 - Steve
