Scan Function
Scan Function
where can i find the band scan function? where can the user set a start and end of a certain frequency, with the loop function?
Re: Scan Function
Click on the "Scanner" menu item at the top of the console screen
Page 134 (PDF page 147) of my updated online manual (left click on PDF-Manuals menu item at the top of the console) talks about the "Scanner" in detail.
But I also have a Youtube video on it as well.
Because I have the 2m/70cm module, I find the "Memory" part of the scanner the most useful for scanning all the local repeaters.
The Band scanner is most useful for the Visual SWR display.
Re: Scan Function
thanks Darrin
Low-High Scan was what I meant.
I would lower the scan speed to 5 msec and also Step in Khz in 500 hz or less, or I would set options to the user's liking for speed and step.
If I may, I would implement this function in the foreground of the screen in the RX1-VFO A area where you select the frequency changes Bands.
I would also add the stop function on the first screen
Thank's for your support anyway
lou
lou
