would there be some way to use multiple available Ominirig distinct and separate? I explain I have the station log that uses Ominirig with powersdr, then cw skimmer with Ominirig all assigned with different port with VSP Manager but when they are both open one of the two does not work or works incorrectly and they automatically assign themselves a common port equal
lou IK8HCG
talking to a friend, if each software that manages Omnirig with virtual Cat was given its own .exe destination path?
Powersdr+Omnirig
Re: Powersdr+Omnirig
Copying Omnirig into different locations might allow you to run them as totally separate instances? All you can do is try and see if it works?
With WSJT-X, you can run 2 separate instances just be launching the program with specific command to use a different rig config. (I have the details on my webpage) but I doubt if Omnirig (which is a much older program) would allow that.
I don't use FT8 activity
what I have tested that you can only have one program with Omnirig executable, other running software that have Omnirig mode are disabled
I found this:
if I disable the function in setup-Cat control- RX A, TX B, Ominirig takes a single virtual Cat in common and everything works regularly without assigning different virtual CATs
- setup.png (495.36 KiB) Viewed 1006 times
