In the manual FLEX-5000_Owners_Manual_v2.8.pdf, page 144 where the functions of the "OK" and "Apply" buttons are described, they do not reflect the reality of the functions expected and desired by the operator.
The database with the settings selected by the operator will only be saved database in the HD (or SSD) when the PowerSDR program is closed.
Would it be possible to change the function of the "OK" button so that it actually rewrites the XML file on the HD (or SSD) reflecting the settings in RAM memory?
PowerSDR database
Re: PowerSDR database
Looks like Flex must have made a change at some point but did not update the manual.
Correct, the "OK" button does not update the Database file, it just closed the Setup window.
Only hitting "Apply" or closing PowerSDR, updates the Database file itself (and only if the Database is not corrupted).
I do not want to change the function of the OK button
But I will correct the manual
