I have a Hercules MP3e2 configured as I assume most would: where VFO A is controlled by the Deck A wheel/knob and VFO B by the Deck B wheel/knob.
Everything works as it should, except one feature: Toggling the “Pan” button to red to enable the bandpass window to move freely while the waterfall remains stationary. This feature does not work when controlling the the VFOs via the Hercules. However, it works as intended when I rotate the mouse wheel to adjust the VFO. Am I missing a setting somewhere?
Thanks in advance,
Tony
Hercules MP3e2 and Pan vs Mouse Wheel and Pan Topic is solved
Flex 3000 & 5000
Hercules MP3e2
Dell OptiPlex 990 w/i5 2400 CPU @ 3.1GHZ
Windows 10
Hercules MP3e2
Windows 10
Re: Hercules MP3e2 and Pan vs Mouse Wheel and Pan Topic is solved
Tony,
When I added the VFO move feature I probably did not add it to the CAT command.
When I get a chance I can see if its easy to fix.
Thanks, Darrin!
Flex 3000 & 5000
Hercules MP3e2
Windows 10
Hercules MP3e2
Windows 10
I haven't been on the air for a few weeks and just now downloaded the latest revision. Thanks for the modification! It works great!
Flex 3000 & 5000
Hercules MP3e2
Windows 10
Hercules MP3e2
Windows 10
