Band Indication for 2 radios
Re: Band Indication for 2 radios
Post by K2GC »
Hmm, not telling it to disconnect.
researching more on this... Oddly the arduino is not reading the response from Psdr either.
Not your issue at this point, as Telnet works fine.
Thanks again!
Post by K2GC »
Still unable to get the arduino to play nicely with it.
I could send you my code if you had one you wanted to try with it....
I should mention, my code communicates fine to VSPE setup as a TCP server to a ddutil port....
Post by K2GC »
Scratch that! I think I have it working now!!
Post by K2GC »
Something I am noticing....
If the arduino is reset, it turns off the server in PSDR, and it has to be manually turned back on. Is there a way we can make that stay on and auto reset itself if it loses the connection?
Post by K2GC »
Video of it in action
https://youtu.be/Sb2Vhk1i6ws
Right click on the ON checkbox to open up the server status screen
If you attached to the IP socket and then drop, it should just disconnect but the ON checkbox should stay ON.
The status screen should tell you why it turned OFF.
Then I can try to fix it.
Post by K2GC »
This shows the log as I press the reset button on the arduino (simulating a power failure to the arduino)
Code: Select all
>>Command Received: ZZBS;
>>PowerSDR sent: ZZBS010;
>>FAILURE: System.IO.IOException: Unable to read data from the transport connection: An existing connection was forcibly closed by the remote host. ---> System.Net.Sockets.SocketException: An existing connection was forcibly closed by the remote host
   at System.Net.Sockets.Socket.Receive(Byte[] buffer, Int32 offset, Int32 size, SocketFlags socketFlags)
   at System.Net.Sockets.NetworkStream.Read(Byte[] buffer, Int32 offset, Int32 size)
   --- End of inner exception stack trace ---
   at PowerSDR.Setup.CATURL()
>>You turned OFF CAT TCP Server.
>>CAT Server Thread stopped
OK It appears to be fixed (when I used task manager to kill the telnet client directly, instead of closing it, and I got the same message as you)
.182 fixes it.
Make a setup->export backup first just in case.
Post by K2GC »
Oops, forgot the backup.... but no issues.
Seems to work much better now. I can still crash it if I am trying 'too hard' to reset and make it recover, but in real world operations, it should be just fine!
Many thanks for your work on this... It has made many more things possible now!
As to my project... the band indication part, I can do it just fine now. Now, I need to get the arduino to talk to both radios at the same time. Each arduino needs to show the Remote radio's current band, but then check the local radio band as well to set the band pass filter. Once I get over my dual TCP connection issue, it should be nothing but a thing.
When its all done and working, I will likely share code someplace, as well as pics of the final setup.
Post by K2GC »
Another question. Is there a point where I can send commands too fast to this? should I keep my 'poll rate' below a threshold? my test code runs at a 1 second loop.... but I would like to bump the speed up a little (maybe 1/2 second?) just dont want to overload it, and make PowerSDR sluggish....
Not sure of the max rate.
But years ago (before I created the Analog meters) I used the Woodbox CAT meter, and its update rate was crazy with a big CPU load.
I would think 1/10 sec is fine. The code all runs in its own thread so you cannot bog down PowerSDR.
Post by K2GC »
Sweet! thanks!
