Flex unkeying before CW string sent
VE3TMT
Post by VE3TMT »
I'm using MixW for sending CW and am finding the Flex shifts back to RX before the CW string is completely sent. Even if I manually hold the PTT button, you can still hear the relay clicking in the Flex 1500.
Ideas?
VE3TMT
Re: Flex unkeying before CW string sent
Post by VE3TMT »
Got this one fixed.
New issue... being plaguing me for a while.
I'm getting a bunch of audio hash when the Flex 1500 first keys up in digital modes. I am using VAC1 for these modes. Does not do it in CW or SSB modes, where VAC is not being used.
I've tried adjust the buffer settings, sample rate (running at 44100) and nothing seems to help.
Any ideas?
Make sure the VAC1 "mix VAC1 and Mic audio" is not ON
Otherwise you would need to look at the program you use for the virtual audio cable.
I use VB-Cable and Voicemeeter Banana for VAC
