My 6m button is now labeled "10", sb "6".
It selects 6m OPS properly, just the label is wrong.
V2.8.0.300 6M 6m Band Label Text
Re: V2.8.0.300 6M 6m Band Label Text
Go download .300 over again and install 2 times. Select Repair the 2nd time.
should be fixed.
should be fixed.
Thanks. Your suggest funky-fix worked.
I am playing with the latest Hermes Lite and Thetis-HL2 flavor.
I sure miss your robust, feature rich, spiffy, PowerSDR.
I'll wager you could charge for a Hermes Lite supported version but that looks to be a boatload of effort.
Cheers,
Randy W7CPA
Cheers,
Randy W7CPA
Make sure to hit the Setup->General->Options->update BandText
Although it doesnt mean much to us in the USA, I not only added the 8m band, I added 4m as well (if you have a Flex-5000).
A couple of years ago Apache labs offered me a Radio to port over my code, but I dont have as much time as I once had.
And my 5000 does just about everything I want.
Testing Thetis HL2 version.
Download the source for grins.
I see your most excllent SPOT code in there.
// Spot.cs
// created by Darrin Kohn ke9ns
// This program is free software; you can redistribute it and/or
// modify it under the terms of the GNU General Public License
// as published by the Free Software Foundation; either version 2
// of the License, or (at your option) any later version.
// This program is distributed in the hope that it will be useful,
// but WITHOUT ANY WARRANTY; without even the implied warranty of
// MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the
// GNU General Public License for more details.
// You should have received a copy of the GNU General Public License
// along with this program; if not, write to the Free Software
// Foundation, Inc., 59 Temple Place - Suite 330, Boston, MA 02111-1307, USA.
// Spot.cs
Well, my code skills are lacking when it comes to portability and readability.
I'm usually writing code on the fly, just trying to make it function, with no clue where I will end up.
