error when opening via RDC
N2SAB
Post by N2SAB »
Darin,
when trying to open 2.8.149 from within an RDC connection, the startup gets as far as "portaudio" and the then the program closes. If I open it from Teamviewer it works fine, no errors.
Any ideas??
Scott
N2SAB
Re: error when opening via RDC
Thats the issue with using Remote Desktop. PowerSDR scans for audio devices only at power up, and Remote Desktop messes with those audio devices, which causes issues. If PowerSDR is already loaded up (does not have to be running), Remote Desktop will work.
Teamviewer works well, and its very easy to use as a receiver, but 2-way audio requires a special trick (which I describe on my webpage).
