Should the panafall mode function independent of the mode selection on RX1? Panafall on RX2 doesn't function unless panafall is selected on RX1 at the same time. I also noticed when RX1 is in waterfall mode and RX2 is in panadapter mode, the RX2 display is jerky. Do I have something set up incorrectly?
Thank you - Jerry
Panafall mode on RX2
Re: Panafall mode on RX2
Jerry,
The jerky motion is because of the setup->General->Hardware Config->DttSP auto restart checkbox is ON.
The DttSP setting needs the Panadapter to be ON. I fixed the code with v2.8.0.109
I dont recall if I was expecting Panafall on RX1 before enabling Panafall on RX2 (its been too long to remember)?
I thought I had them independent, but I will take a look.
