Hi,
i have problem with N1MM waterfall band spectrum usage. After few seconds or minutes the N1MM+ waterfall freezed and N1MM+ crashed.
Also I indicated that signals on N1MM+ spectrum display is moved 500Hz cca.
My setup is WIn10, core I5, 12GB Ram
latest PSDR
latest N1MM+
Flex3000
Do you have somebody good experience eith once and need I better CPU computer?
Tom OK1DWQ
PSDR+Flex3000+N1MM+WB - crash issues
- - - - - - - - - - Just for shared economy - - - - - - - - - - -
Public free remote transceiver OK1DWQ-G on Ramoteham.com
100W Flex3000 + 4SQ/40m FullVertical80m InvL160m InvVee 40/80m
Re: PSDR+Flex3000+N1MM+WB - crash issues
It looks like if you hit the start/stop or resize powerSDR console, it freezes the N1MM spectrum display, otherwise it was working.
I was able to get it to run again, by unchecking the N1MM Spectrum box, waiting a few seconds, and rechecking it.
But I will look into it.
I tried to use it in ARRL RTTY contest but it was unusable. After few seconds (but it was diffrent) the WF in N1MM freezed. I didn't recognize of dependency what.
I just uploaded v2.8.0.148
I added FPS setting, so you can slow down the data transmission to N1MM.
So instead of the normal 7, try 5 and see if that helps.
Now, it's work very well....
thank's for update. It is usefull now.
Still continue problem with SO2V opration with N1MM+. When I switch between vfo entry windows after doing a qso then revert to previouse vfo/a the monitore status is going to next one status and usaly I don't here own CW monitore signal.
N1mm+ has no control abve CAT send commands in this operation.
Tom ok1dwq
Tom ok1dwq
Tom,
I not sure I understand what problem your having with SO2V
I would need more details on the exact scenario your trying to describe?
