Suggestion
artdriggers
Suggestion
It would be nice to have SWR plot information stored as a spreadsheet or text file.
Re: Suggestion
I will take a look at doing that.
Re: Suggestion
Hi Darrin, any chance od an "extra" set of band-buttons for the 2nd receiver instead of the drop-down box (lower left)...i now have widescreen monitors lol; so i can now display the meters on top etc and it looks like there might be a "little real-estate" above the 2nd rx mode/filter-width buttons or inbetween them both ?
Flex 5000A 2 RX, Palstar AT2K
"Hackintoshed" Gigabyte Z390 M, W7(mod USB) + OSX 10.15
Digi 002 mixer & ProTools 10 HD & Logic Pro X
Behringer C-1, Yamaha CM500 headset & Panasonic WM-55D103 electret
Hercules DJ Control MP3 E2
Re: Suggestion
I was just trying (unsuccessfully) to open the "ke9ns_SWR1.dat" file to compare readings taken via the radio vs those taken with an analyzer at the antenna feed point. Since I couldn't figure out how to open the file, I searched the forum for info and came across artdriggers suggestion to have a way to save SWR as a text file. I definitely second the request. I think it would be very useful. Please consider it if its not too much trouble.
Flex 3000 & 5000
Hercules MP3e2
Dell OptiPlex 990 w/i5 2400 CPU @ 3.1GHZ
Windows 10
Hercules MP3e2
Windows 10
Re: Suggestion
With .166 there is now a SWR_PLOTS folder, and every SWR run you make creates a .csv spread sheet file of the SWR.
Right click on the SWR SCAN button to open the folder.
Darrin ke9ns.com
Darrin ke9ns.com
Re: Suggestion
Outstanding! Thank you Darrin!
Flex 3000 & 5000
Hercules MP3e2
Windows 10
Hercules MP3e2
Windows 10
