strange error on PowerSDR v2.8.0.249 Topic is solved
hb9ncz
Post by hb9ncz »
I have a strange error when starting PowerSDR.
When I click on the Memory button, the following error appears:
" Standard-errordialogfeld for "DataGridView
DataGridView-exception
System.ArgumentException:
Value "DataGridViewComboBoxCell" is invalid"
this error recurs every time you start PowerSDR,
you click several times on OK then appears
the Memory window.
then close the Memory window and reopen it,
there are no more errors
with Windows 10 last update
Roland HB9NCZ
Re: strange error on PowerSDR v2.8.0.249
Something happened to the frequency Memory.xml file in folder: %userprofile%\AppData\Roaming\FlexRadio Systems\
You will probably want to remove the file and let PowerSDR create a new empty file.
Or you can try to fix the existing file (if you know how to edit and repair xml files)
hb9ncz
Re: strange error on PowerSDR v2.8.0.249  Topic is solved
Post by hb9ncz »
Hello Darin
Thank you very much for the information,
I looked with Visual Studiocode at the "memroy.xml" file and noticed that in the last record,
there was a registration error in the "<Group-Feld>.
I corrected this error and PowerSDR could open the file again.
Roland
HB9NCZ
